Central channel speaker
kaushik_dhume
goa
Is it absolutely necessary that my central and surround speaker be of the same make as my towers ( in my case wharfedale towers 10.6) ?.Wharfedale 220C is quite costly when compared to Mission LX-C and MX-C1 ( when checked On HIFI mart ) . Will These be gud enough ? There is also the Taga Harmony PLATINUM C-90 SL and Boston Acoustics A 225C .All of these are in the price range of 10k-13k. Wharfedale costs 17K.
Considering the fact that i am not a big movie buff and watch movies once in a while , is it ok to buy one of these cheaper speakers or should i stick toWharfedale? And if the answer is yes which of these would you suggest? What is the difference between mission LX-c and Mx-C
Kindly clear my doubts and oblige
Sent from my MotoG3 using Tapatalk
It's been answered in ur other post. Stick to that. Elango has answered. Use center same, ur rear surrounds could be different sir.
One thing necessary is patience [emoji4] . Don't start different threads on the same topic. It will only lead to confusion.
People will reply. Give it some time.
Do not skimp on the center speaker. It is the most important speaker in your surround setup. I have used heterogenous setups in the past and not noticed much difference but some people might. It is safe to stick to the same brand/series LCR - surrounds can be different.
Thank you.will do as advised as majority are laying emphasis on the central speaker
