Cheap and best 100" or 120" or 200" screen
rammy
Guntur
Dear forum members,
Could you guys please suggest me good cheap and best screen 100" or 120" or 200" ? Where have to buy it? and also best quality projector recommend me too?
Thanks in advance
ramesh:ohyeah:
You have not indicated whether you require motorized or fixed frame screen.
Motorized are cheaper but develop wrinkles over time.
Liberty or Winger are probably the cheapest brands in the market. Call your local dealer for the pricing.
I bought from ebay - MAP TYPE HOME CINEMA PROJECTOR SCREEN IN 16:9 FORMAT, 100 inch for 1800 (hanging type) - basic. I thought of using this for few months to see how it all works and go for good one once my HT is stabilized.
I am still using it and don't have any issues. The wrinkles may only be visible when the projector is not in use. Otherwise it's all good to go.
of course, you can decide on yourself what you want.
