Coaxial cable for Helix DSP
sandeeprao
Noida
Need a Coaxial to 3.5mm wire to connect my phone with Helix DSP - Please do suggest if you know who can help me with this.
If you are looking at analog interconnect Try this Audio Quest Tower or forest series.
Thanks for the response @balavignesh002 - I think I asked the wrong question.
I thought I will be able to connect DSP with my phone directly with this setup - but batter after researching a bit more I got to know it is not possible and will have to have other source for DSP as SPIDIF input or use phones output as RCA in (which might not give great quaity sound).
If you want to use phone as source, you can use USB DACs like AKHC4, Cayin RU6 etc and connect using analog interconnects to DSP. This plenty of usb dac options available in market.
If you want to connect using optical or coiax, sources with digital out is quite less in the market.
Another way is to use an android headunit and connect it to usb dac, if the usb dac has an optical out you can leverage that or use the analog out to DSP.
I used the first option which I mentioned in Vento
Superb ..... thanks for all the suggestions.
Initially, the idea was to connect the phone using the deck, but I thought I could connect it directly to the DSP using a USB deck.
However, it now seems that I have to go with the BT HEC card for ease of use.
I didn't recommend this option for a reason. For SQ this HEC BT module and fiio BTR5 doesn't make much sense via bluetooth streaming, they are ok for phone call though.
To get optical out from mobile you can use Topping d10, smsl 100 pro, fiio bta30 pro etc these all had spdif/optical out. Connect phone to any of these & give optical/coaxial out to dsp. Best solution.
Out of these fiio bta30 pro had volume control required only if you don’t had remote control for dsp, else smsl is the vfm option.
Vikas
Instead of BT add on, why not use helix provided USB addon?
Not much if difference in SQ will be noticed if the source of music is Spotify, Amazon music etc....
Thanks @swift - got the BT HEC installed in my car yesterday.
1st impression, sound stages have improved & harshness gone
