Coaxial Cable
sorry, not here to help you but out of curiosity.... what is the price of these cables?
Currently using Bandridge coaxial cable to connect Blu ray player with Marantz 6006. Will changing to AudioQuest cable improve the sound?
Cables should not add or subtract anything. What matters for interconnects in technical terms are low capacitance, minimal length, proper insulation from interference, good connectors and termination. There is some difference in sound signatures between copper and silver quoted or pure silver interconnects. Tinned copper cables are also very good.
Audioquest has a number of series. They are good cables, but price-to-performance is a pure personal thing.
As a thumb rule stay within 10-15% of the total setup cost for cables.
Have a look at Mogami W2964 SPDIF 75 ohm digital cable, you can get it from sound foundation or hifimart.
They are well made and not crazy expensive.
Recently I purchased same cable to connect my AudioLab 6000CDT to Denafrips Areas II DAC.
Yes, there is a possibility if you are using a long cable currently. Keep your player as close as possible to Marantz to reduce the length.
Once decided on length, see if you can order from designacable.com. They use good connectors.
