compatible AV receiver for onkyo speaker system
tjjeykumar
chennai
hi
i have onkyo HTS 3400 system of which the av receiver been not functioning. I am planning to replace the av receiver. The speaker system i have is onkyo skf 390 . I need to know which AV receiver will be compatible to my speakers. I am thinking of buying Yamaha 3067 AV receiver. Would like your feedback. THank you
Depending on your budget, audition and decide which AVR you want. Check the specs and impendance.
Check the pre owned section "For Sale by owner" or Hi Fi Ads....you might find something
In the same boat as OP. My 10 year old Onkyo HT-S580 may be dying. All speakers that came with package are passive (including sub). I guess the most sensible option will be to buy a new set of speakers and AVR. The reason being -
- New AVR with may not work well with old speakers
- It will be difficult to get a good AVR which supports passive sub
