Confusion regarding speakers
delhi
Hello,
I have a confusion regarding the compatibility of speakers, if i buy speakers and center channel from USA and buy Receiver and subwoofer from India. Will it work and compliment?
There is nothing like 110volt or 220 volt in the speakers rt? its only for the subwoofer and receiver rt?
unless u r opting for active speakers voltage rating is not a problem since ur speakers are connected to ur amp only. Yes voltage rating is for amplification and subwoofer which has built in amplifier
Just choose the Center and front speakers from the same manufacturer and preferably the same line. Surrounds can be matched later and can be from the same or different manufacturer. Same goes with sub-woofer, just buy a good one. As others have pointed out apart from sub woofer, no other speakers are connected to electrical socket.
