Hi. I have a Logitech Z906 connected to my PC and I was wondering if I can connect Yamaha's NS-P150 (left, right and center only) to the Z906. And Will I get improved results over my current setup or Not?
Z906 Specs:
Power Rating (RMS) 500 Watt (Total Power) (165W Sub + 5x67W Satellites)
Sound Pressure Level (SPL Max) >110 dBC
Frequency Response 35 Hz - 20 kHz
Signal-to-Noise Ratio (SNR) A weighted: >95 dB
Input Impedance 8,000 Ohms for analog, 75 Ohms for Digital Coax
NS-P150 Specs:
Center Speaker Woofers Dual 3-1/4 cone
Tweeter 1/2 balanced dome
Frequency Response 65 Hz38 kHz
Nominal Input Power 30 W
Maximum Input Power 80 W
Sensitivity 86 dB/2.83 V/1 m
Impedance 6 ohms
Surround Speakers Woofers 3-1/4 cone
Frequency Response 60 Hz38 kHz
Nominal Input Power 20 W
Maximum Input Power 60 W
Sensitivity 82 dB/2.83 V/1 m
Impedance 6 ohms
Thank you Very Much!
Z906 Specs:
NS-P150 Specs:
Impedance 6 ohms
Impedance 6 ohms
