Dali e-f12 original packaging
yulejie
Sweden
Are there anyone, who had bought Dali e-12f subwoofer, could still remember if the sub comes originally with the rubber pads on the metal foot out-of-box?
I just bought mine but found there were already 4 rubber pads on the bottom and another 4 in plastic bag. As I have also bought the Zensor speakers and none of those have those pads pre-installed, I am wondering if I have bought one returned by others...
Thank you :)
Best regards
I'm not sure about the packing but a good way to check would be to check the date of import/manufacture and the serial number on the box and then match that serial number with the one on the sub.
That way you can see how old the sub is.
I am only able to find the serial number on the box and the sub itself (and they match), but nothing obviously indicating dates... I think the simplest is still to ask one who could still remember how it looks when unboxing :)
Thank you.
In that case your manual will give you the exact contents of the package.
See if they are shown separately or assembled.
