Dali Zensor 7 Speaker cover
Chaoseater
My little one went on exploring speakers and ended breaking up the speaker covers and the speaker cover fasteners ended up breaking.
Is there anyway to fix it ?
1. When you say covers, do you mean the cloth only or the frame also?
2. Are the fasteners stuck in the speaker body?
1. Its not stuck anywhere, its broken and seperate. Maybe the cardboard can be fixed via Fevikwik.
2. Few fasteners are stuck and few are not.
Would fasteners like the below will help in fixing the issue.
I had broken fasteners on some speaker grills some time back.
I drilled out the broken tabs from the speaker body and then used cylindrical magnets to go into the tab holes and stuck flat disc magnets onto the grills. Results were excellent. Also rendered the covers much easier to remove and fit.
You can buy speaker grill cloth from https://theaudiocrafts.com or https://diyaudiocart.com or you can even use spandex material.
You could also get in touch with Mr. Murthy who does a lot of audio stuff. He is on Commercial Street.
Search for his details on the forum. He has been mentioned several times.
