Definitive Technology Supercube 2000 vs Polk PSW110/Klipsch SW350
k11
Chennai
Which subwoofer should I choose.
For living room 20X15. Open type, movies 90%, Jamo S426 speakers
All subs except Def Tech is from India.
I am getting a good deal on Supercube, (Asian version) import but will work with Indian plug point.
Def Tech Supercube - 10inch cube with 7.5 inch drivers and 2 passive radiators
Polk PSW110 - 10 inch driver, front firing
Klipsch SW350 - 8 inch downfiring
Jamo Sub 210 - 8 inch downfiring
Def Tech - Around 20K (Import for 15K + 5K shipping)
Polk - 15K
Klipsch - 27K
Jamo - 19K
Def Tech Supercube is the only one with 2 radiators on side.
Auditioned it, it sounds very good. Not sure if the radiators made the difference.
I am getting the Def Tech through the company outlet from US.
These subs work with AC voltage.
Polk - 15K
Klipsch - 27K
Jamo - 19K
I am also looking at this sub. What amp are you using? Do you think Marantz M-CR603 (2x60 W amp) can drive this sub?
Not sure about Marantz. I am a newbie.
I got Pioneer VSK-821K. It has sub out.
Def Tech supercube has LFE input so it should work with any receiver having sub out.
Velodyne Impact 10. Probably falls in the same 20K range.
How do you think it compares against Polks PSW110/Klipsch SW 350 and the Supercube.
I am still apprehensive about the performance of 7.5 inch driver of supercube. Would it fill the room.
Cost of the supercube sub is more than my Jamo package itself.
Finalized on Def Tech.
Ordered the Supercube. Will update on performance soon when I get it hands.
