Denon AVR 1712 vs 1912 ?
ManishM
Mumbai-India
I am confused between 1912 & 1712.
Does they give same quality output?
I DONT need airplay & network capabilities
Hence except airplay and network is it ok to buy 1712????
You do not care about networking capability and airplay. That is fine.
Apart from the above, the 1912 will be able to convert analog video to digital over HDMI. The 1712 will not be able to do that.
If the cost difference is not too significant (to you), I will suggest the 1912.
the only real drawback is the radio tuner... on the fm you can only scan channels 91.9 91.1 91.3 91.5 91.7 and so on.... so if you want to listen to fm 91.8 well you cant...same thing for the AM channels 780,790,800 but if you want to listen to 783 you cannot... this by design...apparently the some genius engineer was working overtime. i am not sure if this problem is with all models of denon or only the 1910 model plus the model i have is the usa one not sure if the same problem exist around the world or not .
