Denon AVR-1911- Feedback Required
mdusen
Planning to buy Denon AVR-1911 in US and bring to India. Could not locate any service center in India for Denon. Is there any service center in India for Denon?
But none of them will Service your Denon since its not bought from them. Each of the Distributer whether Profx or Kei service products brought through them only.
The AVR itself is a robust guy - not much that can go wrong with it unless you mess with the power inputs, earthing etc!
Have a 2106 for the past 5 years and its been doing great.
no worries get a good STEP DOWN ISOLATION Type 1KvA COnverter and connect yr avr with it...stepdown will cost u another 3-4k
Hi Hemant,
Can you advise as to from where an isolated step down of 1 KV can be bought for 3-4 K INR ? I have not been able to find one for less than 6.5K so if you can provide the sellers contact details i can save me some $$ :)
