Denon or Onkyo ? which is better
Arora
New Delhi
Need advise as am planning to buy a HTIB for myself and my budget is 30k.
My usage will be 70 % for movies and 30% for audio. I have short listed two Htib's in this range
Onkyo 3200
and Denon 390 xp
Please advise which is better and if there is anything what you can recommend
Thank you
Have you heard any of these? if not, I suggest to make a trip to the store you are buying it from and listenign to them.
Also search around on these forum There are a lot of write ups on the same.
If youa re being charged 30K for the HTiBs then its on the very high side. It should be much lower.
Onkyo 3200
and Denon 390 xp
Thank you
Denon avr 1910
have decided to go for Denon Avr 1910. I found it better than onkyo tx-sr-607. Anybody please advise me which speakers i should add to Deneon 1910 so that it can be a good match.
Initially will be going for front tower speakers now and the budget is around 15-20 k max. My requirement is 50% music and 40% movies.
please also let me know what could be the best price of the denon 1910 receiver so that i can bargain with the dealer.
Will sonodyne sonus 2605 V2 match with the above receiver.
saurav
