denon or yamaha
naim audio
Yelsmana, as I told you that I am getting the naim audio here in india so would you recommend it, as it is in my reach also (financially). everything else is crossing 4000 usd either it is sim audio moon 600i or mcintosh or t+a or burmester.
yes, naim audio is very well british made and i personally like the sound quality...it is very musical and i enjoy it very much... congratz....
vikas varma
Hi Yelsmana,
I wish to give you a news that I have found some used mcintosh(1 year or two year old) in just 700 usd - 1500 usd on the site carstereo.com. Should I consider that? I have found the models like mc2102 power amp and mc2000 etc. Should I trust these?
I never recommend to buy used item especially if you do not know the source very very well...and secondly eventhough 1 year old the price will not drop drastically...so be careful on that.. stick to your original plan, especially if you want to use it for a long term.
vikas varma
O.k dear, yes I wish to use it for long term ofcourse. May be it will take time to get the best amp for me but for sure I will go for the new one.
regards
vikas varma
Hi Friends,
I am newbie to the world of sound. I thought of buying HT, after I got a Asus Mediaplayer and Tata Sky Plus HD. But, the 'lock' is I am tight on budget, preferably 15-20k.
My first query is, can I go for Active woofer and speakers with Optical and Coaxial outputs (there is one in Mitsun).
Or I 'compulsorily' need to buy an AV receiver? If so
Can I go for a Mitsun 9000 (around 7k without speakers) or Onkyo 3400 (around 25k with Onkyo speakers)?
Watch a lot of downloaded movies and Listen to Music. My room is 16 by 10. Using Panasonic Plasma.
I am somewhat convinced tat I need to go for an AV receiver than Active woofers to get a better output. However, can the cheaper Mitsun model along with good speakers can match Onkyo? Do Mitsun have similar configuration and output like Onkyo (with Onkyo being charged higher because of Brand Value)?
If so what are the best speakers (within my budget) that can compliment Mitsun?
If not so, Can Onkyo 3400 with its combo speakers is the best buy?
Excuse me for a detailed query. Hope your suggestions can clear my mind and focus on one...Thanks
