diy projector project
gr_babu
hi guys
i am planning to build a hd diy projector,
please throw in some ideas so that we could start as soon as possible.
its better if we could build a full hd projector if possible.
ideas are welcome
lets all join and make this thread a sucess.
thanking you all.
babu
where in chennai do we source the materials .
if we go for a 22" hd lcd monitor, are the lenses available for that size.
Babu, did you first search on hifivision before starting this thread? Lots of info around, members here have done it. Starting new threads leads to useful information scattered all over the place:). All the best for your project.
About how to get HD easily, just ensure the LCD monitor you rip apart is a HD. If it has a HDMI connector or a DVI connector, it is likely to be HD. Check the specs though.
i understand that ,
but fresnsel lens available in india are of maximum size is 310mm*310 mm, that is the size less than that of a 15.6" lcd monitor. no 15inch lcd monitors are full hd or does have a hdmi connectivity.
using a hdmi to vga converter serve any purpose, whats the maximum resolution we get when a hdmi to vga converter is used.
thx
