DVD Player - Region Free
pnreddy
Hyderabad
I have a Philips DVP 320/69 DVD player. I am unable to play Region 1 dvds on this player. Can anybody suggest a solution for this.
Thanks!
P. N. Reddy
Thanks!
P. N. Reddy
Unsupported hack:
1. Start the player without any DVD in it.
2. Eject the tray and leave it open.
3. In the state press 9-9-9-9-0
4. You should see region 0 displayed.
5. Close the tray.
6. Power off/on to double check.
Your DVD player is now region free.
Dear Marsilians,
Thanks for the prompt reply. I tried out your suggestion and it worked kike a charm.
Thanks once again.
P.N.Reddy
