DVI to HDMI cable
sanjgupt
Where can I get DVI to HDMI cable in Bangalore?
I have a macbook. it has mini-DVI port. I want to connect it to my LCD.
I already have mini-DVI to DVI convertor cable.
Sanjeev
Sanjeev
Go to SP road in bangalore.Its near Townhall. After entering SP road on de left side you wil find a shop with a big MX board who is the dealer for MX accessories in SP road. You wil get a good MX cable Cost not sure ,just inquire and bargain..
There are 2 retailers for MX brand on S.P. Road
Platinex enterprises
20A Shree Market complex
2 T. P lane SJP road
Phone - 9845017065
Samson electronics
Hopak complex, punganoor,
Ram lane, SP road
Phone - 9448829052
hi
i have lg E2040T LED monitor with 1600x900 resolution and dvi-d port input.HOW can i connect it with airtel HD Set top box which is having HDMI output???
Guys any answers?
I have an unused DVI to HDMI adapter which I bought from ebay. This will work either way ie; DVI to HDMI or HDMI to DVI. Audio is not supported. You can also buy DVI to HDMI cable. If you have a spare HDMI cable, then you need to buy only a DVI-HDMI adapter. While buying, check for the number of pins in your DVI out. There are 29 pins and 24 pins variants.
eBay: dvi hdmi
