Elac cinema 5
1.How is ELAC cinema 5. I want to buy it for my AVR (Yamaha RX-V 585)
2. For Atmos can I use normal satellite speakers like JBL
Hi, if you state your budget, room size it can be of great help to recommend other systems than the Elac. Also if you are open to stand alone bookshelves instead of straight wall mount.
My room size is 8mx6m ceiling height of 3.5 meter. Budget is near to 40k
That is a large room. You can look at Taga Harmony speaker packages.
I am sure others will join in and recommend other systems.
Average at best. The sub woofer is also average. Small Plastic body speakers, wood preferred. Good for a small room.
Positive: small compact wall mountable.
Elac 5 is good but only for smaller rooms(below 150 sq ft). For your room, you can consider the following.
Taga Harmony 606 SE Package @ 37K.
If you can increase your budget by a bit, you'll have the Wharfedale DX 2(5.1 package). Has really good reviews and is ideal. It's a steal @50K.
These satalite speaker system won't be enough for your room size.
If you are limited on budget you can buy 2.1 channel now and add surrounds later.
Bookshelves/floorstanders from Dali, polk or elac would be best bet
