Emotiva 5 Ch Power Amp for $399
darshanjoshi
This looks very interesting.
UPA-500 Five-Channel Power Amplifier | Emotiva Audio | High-end audio components for audiophiles and videophiles, spanning 2-channel music systems, as well as 5.1 and 7.1 home theaters. Products include multichannel amplifiers, stereo amplifiers, and
SPECIFICATIONS
Topology: Fully discrete, dual differential, high current, short signal path Class A/B
Number of Channels: 5
Power Output
(rated power; THD < 0.01%):
120 watts / channel (4 ohms; all channels driven)
80 watts / channel (8 ohms; all channels driven)
Rated Power Bandwidth (at rated power; 8 Ohm load): 10 Hz to 20 kHz + /- 0.06 dB
Minimum Recommended Load Impedance (each channel): 4 ohms (which equals one 4 ohm load or two paralleled 8 ohm loads per channel)
Frequency Response: 10 Hz to 70 kHz (+ 0 / - 3 dB)
THD + noise: < 0.01%
Signal to Noise Ratio (8 Ohm load):
> 96 dB at 1 watt (A-weighted)
> 117 dB at rated power (A-weighted)
Damping Factor (8 Ohm load): > 500
Speaker Output Connections:
Full-sized 5-way binding posts; one pair per channel x 5
Power Supply:
0.85 kVA toroidal power transformer
40,000 uF of storage capacitance
Input sensitivity (for rated power; 8 Ohm load): 850 mV
Gain: 29 dB
Input Connections: Unbalanced (RCA); one per channel
Input Impedance: 47 kOhms
Trigger:
Trigger Input: 5 - 20 V (AC or DC); <10 mA input current required
Trigger Output: 12 VDC; can drive any load up to 50 mA
Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched)
Front Panel Controls and Indicators:
Standby; push button (changes color to indicate Standby or On)
Status LEDs (one per channel); illuminate blue for normal operation or red to indicate a fault (may be disabled by rear panel Status LED switch)
Rear Panel Controls:
AC Power switch; rocker switch (switches AC mains power)
Status LEDs switch; small slide switch on left rear (disables front panel Status LEDs and dims Standby button halo lighting)
Protection: The UPA-500 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions. If a fault occurs, the UPA-500 will return to Standby mode, the Standby push button will light amber, and the Status LEDs will flash red.
Dimensions: 17 wide x 3.375 high x 16.5 deep (includes feet and binding posts)
Weight: 22.9 lbs (29.4 lbs boxed)
Hi Friends,
Can we arrange a Group Buy for Emotiva Amps from US? Interested guys pls advice. This amps has excellent feed back and price is very reasonable compared to Amps of these specs.
Hi Friends,
You can start a new thread in deals section with the name as Group buy.There is a discount going on as Summer sale.
Is that only due to power?OR performance?
Power and Performance both.
I am in no way saying they are bad.
The UPA-200 is pretty decent or rather ok-ok. (I've heard the UPA-2, I guess they have re christened the name).
Cant say much about the UPA-500 though . by 80 watts x5. you are not going to achieve a lot over your existing AVR
However considering the $ exchange rate + Customs + Shipping. I would rather go for a pre-owned PA's
The best part of buying an Emotiva is, you can do direct purchase from the company and probably crack a better deal than a Group Buy. A colleague picked up their XPA-5 for a landed cost of Rs. 62000 during last years Independence Day sale. This includes the cost of the amplifier, shipping via FedEx and Customs duty. Paired with a Polk Audio Rti A9, the XPA-5 is serious sound for the money. The drive is effortless.
htstore.in had this very same power amplifier for sale some time ago for Rs. 95000. I do understand that you need to make margins but this is just ridiculous. Why pay the over heads when you deal directly with Emotiva.
