EQ for Mac
Doomster69
Gurgaon
Can someone here suggest which is the best parametric eq software available for mac OS that works system level (i.e. eg for spotify streaming to DAC via mac's usb). Iv used trial versions of audirvana to good use, but the subscription is too expensive. Read EQMac is buggy and requires a full system if someone wants to remove it. Similar use reviews for some other apps from Appstore.
Im using pine player for playback of local files, looking for a streaming services eq solution.
Any one has experimented or is using a reliable app worth trying?
Tx
i spent a lot of time reviewing trial versions and came to the conclusion that Audirvāna is the best by a distance. The cost is high but worth it.
