ESL-2805 @ Boomerang Audio - Audition !!
bhagwan
Mumbai - Bombay - INDIA
http://www.quad-hifi.co.uk/esl2805.htm
Hello !
The Quad ESL Speakers are there @ Boomerang Audio - Juhu - and can be auditioned.
I would recommend a visit;
Comments & reactions too would be appreciated.
SHANTI
Format Full Range Electrostatic
Membrane 0.5g/m2 Tensioned film
Panel Elements 4
Time Delay Progressive concentric rings
Chassis Heavy duty composite aluminium / steel
Maximum Power Output 2 N/m2 at 2m on axis
Sensitivity 1.5u bar per volt referred to 1m
Impedance 8 ohms nominal
Maximum continuous input voltage (RMS) - 20Hz to 20kHz 10V
Programme peak for undistorted output 40V
Permitted peak input 55V
Frequnecy response 35Hz - 21kHz (+/-3db)
33Hz - 23kHz (usable)
Distortion (100dB @ 1m) Above 1kHz 0.15%
Above 100Hz 0.5%
Above 50Hz 1.0%
AC Input - double insulated 220-240V (European models)
110-120V (American models)
Power Fuse 63mA anti-surge, 200-240V
100mA anti-surge, 100-120V
Power Consumption 6 Watts
Dimensions 1040mm x 695mm x 385mm (add 25-55 mm for feet/spikes
Weight 34.8kg net
I want to contact Boomerang audio to audition the Totem Arros. Unfortunately, don't have a number! Can anyone help?
The dist. for Totem in India is:
Marbin Rusatm Colah
Innovative Information Technology Ltd
Audio Distribution Group
1507 Maker V, Nariman Point;
Bombay 21, India
FAX: 91 22 5 630 1209
Tel: 91 22 5 632 5010
Mobile: 91 9819257839
E-mail:[email protected]
[email protected]
Unfortunately Marbin does not have the Totem Arros in stock so I doubt you will be able to audition them.
