naveenm
My current entertainment setup is the following..
Amp is Marantz SR5001,
Projector is Panasonic AX100,
Speakers are Definitive,
woofer is a velodyne
player is Denon 1930
I plan to go in for an Xtreamer so that I can play movies off a hard disk and also use the other connectivity options. My concern is..would I be able to utilize my existing sound system to the fullest if I get an Extreamer?
I had read a thread somewhere that mentioned Xtreamer does not support HD Audio through a Marantz amp. Has this been fixed? I had spent a fortune on the amp, speakers and woofer :/
Awaiting your reply. Thanks in advance.
Kind regards,
Naveen Murugesan
Kind regards,
Naveen Murugesan
