Grundig V5000
Vito_Black Baron
Greece
Hello everyone ,
Recentrly i bought the Grundig V5000 amp and it has a problem . When i change the db level knob it starts to do some weird things , it mixes the channels and generaly it does not work as it shoud . Only in -2 possition it works well .Do you know where to look ? What i can check to find the problem ?
Yes, I could help. You need to check the PCB, where the level switch is connected, and Replace tantalum capacitors. Greetings Mike
