hdmi cable suggestions
piyush608
new delhi
i will be connecting my denon 1713 to my PJ through hdmi
very long hdmi cable will be required my room dimension are 10*13*10(lxbxh)feet
i will be putting my pj on opposite wall(position not finalized) i.e 13 feet far(to get max scree size)and
planning to run HDMI cable along corners of floor(suggest if any other way).
i think i will be requiring 30feet cable(roughly)
some info:
room dont have end to end carpet
dont have false ceiling .
plz advise on what length of HDMI will be required and also some pointer from where i can buy hdmi cable (not very expensive ones like gold plated and all)tried and tested by FMs
Will there be any significant pic quality difference if I use 1500 rs cables from eBay..as compared to 5k.ones like profgold and all...I will be playing 1080 p ripped movies ...and shankar plz send the link from when rich u have bought this cable ..
I will be connecting Acer h5370bd to avr 1713
thanks for the info...can you please give me a ebay link for a particular cable of 40feet
..thanks in advance
I could not find a good (and cheap) cable of 40ft length. In case you are ready to spend around 3k and can manage with a 35ft length you can have a look at these:
Mediabridge Ultra Series - High Speed HDMI Cable with: Amazon.in: Electronics
Aurum Flat Series - Flat HDMI Cable with Ethernet: Amazon.in: Electronics
These cables got nice reviews in amazon.com. :)
Four years ago, long HDMI cables were not easily available, unfortunately. I used two 15 feet cables and joined them by a coupler for my connection (AVR to 720p PJ). This arrangement works fine.
The HDMI cables are not branded and/or expensive. Can't remember exact price but the two cables and coupler did not exceed Rs. 3000. Now cables have become even cheaper.
I found the 15m cable mentioned in my post locally in Nagpur for Rs 1500. Surely they must be available in Delhi. Just scout the electronics market.
