HDMI to Digital Coax to HDMI...Is it Possible?
accessguru
Edmond, OK
I'm buying a new house that has a digital coax run from one of the walls to the mantle above the fireplace. Is there a converter to change from a HDMI console like a PS4, run it across the digital coax, then convert back to HDMI to the TV?
Also, what kind of degradation would occur?
There are hdmi over ethernet adapters which you can try, but you will need to rewire using CAT cables.
Converters are available for both types. But my understanding is that co axial carries only audio. Do you have two parallel co axial cables available ? in which case the other can be used for video
