height and width channel speakers help!!!
harsha.chelikani
Hyderabad
Hello everyone...i am gonna buy dali helikon 400 mk2 floorstand and the centre speaker from the same line...My friend has the same setup with dali ikon 2 bookshelves surrounds as helikon series surrounds are as costly as the floorstand themselves..I have several questions in my mind...
1)Is it ok to use ikon series as surrounds cause if im not wrong you need not have as powerfull speakers as fronts for surround..
2)Or is it a possibility to use better bookshelves from another manufacturer like psb imagine b etc as surrounds to get better sound from surround...will they match the dali fronts or its better to go with dali ikon though they arent the best in bookshelf..
3)Similar query regarding height channel and width channel speakers do i have to use dali ikon or is it ok if i use another manufacturers bookshelves..will another manufacs bookshelves sync well with dali helikon fronts
