Help in building a new 5.1 Home Theatre (Budget: 80-100k)
Sanchitpkl
Delhi
Need help in building a new Home Theatre for my living room (18 x 14 ft)
I have decided to go with Yamaha but confused between YHT-3072 and RX-485 (Only change I believe is Wi-Fi, and since 99% of the times, my input source would be a Smart TV, does Wi-Fi feature really matters? Is there a difference in audio quality between these 2 Yamaha models)
Also, need help with deciding the 5.1 speaker set. I have auditioned Yamaha NSP-41, Polk Audio TL1600, Elac Cinema 5 (Local Dealer had only these speaker set which were in my budget range) and I found Elac Cinema 5 to be better out of these 3. But, I am not sure if Elac Cinema 5 is the only best possible option which fulfills my below requirements. Hence, need suggestions from the experts on the best 5.1 speaker set which fulfills my needs and won't need an upgrade for alteast next 2-3 years.
Requirements:
1. Due to space constraints, I don't need Tower/Floor standing speakers, only Wall-mountable speakers
2. Usage would be 50:50 with Music and Movies
3. Budget range for speakers- 40-60K
