HELP !!!! Looking for setting up a hometheatre...for first time
vicky11
Hey GURU's
I am new to forum and seeking for help and guidance.
Looking to setup a hometheatre for a room sizing 18 x 14
Use will be Movies as well as Music .
I had browsed thru net and found few basic AV recievers.
Yamaha : 367 and 467 , even 667 looks good but budget is very high
Onkyo : SR308
Harman Kardon : AVR134
with speakers which i auditioned JAMO s426 with Sub A210 . Is this speaker good enough ? specially the Sub , also is this active or passive sub ? as the i cdnt get much punch wen i auditioned it.
I am very budget consicous and looking for something arnd 40k to 50k
Can you please suggest something better , I stay in mumbai so any outlets to check for the same
Thanks a lot
Friends please do help me out guys .
I am like big time confused on this things , apologies if I have been insisting too much .
thanks & regards
Well you can get onkyo 3400 / 5300 which will fit your budget.
Denon 1311 Pack costs more than 3400 but is supposed to be a better than Onkyo if you like Denon Sound.
You can also look at Denon 1611 with Mission Speakers ( BS , not FS) , the punch from Sub was just right.
Thanks a lot Jatin ,
will surely try and get a demo for Denon as heard a lot about it.
But any idea abt those floorstanding JAMO speakers s426 as am very confused . But I wish to go with floorstanding as that are coolest looking speakers but has anyone used or had any experience of JAMO speakers specially the mentioned model.
Thanks & regards
