I have a pair of Polk Rti A3 and a Polk hts 10 subwoofer. It is paired with a Norge 2060 Stereo amplifier. These are installed in my living room.
They are my first bookshelf speakers, and while they sound better than anything I have owned before, they don't sound as good as they did in the store demo in a completely treated room. I guess the trouble is the acoustics of my room. The bass gets boomy for some notes and has a reverb, in the sense that if i stop playing a track, the bass lingers for a second.This happens even if I turn off the subwoofer. There is reverb in general, noticeable for vocal frequencies too.
The living room right now is mostly unfurnished, except for a chair and a table. I have added photos and a (hand-drawn floor plan ).
Eventually, the TV and amp etc will be place on a table, and there will be a couch. The cot and all the stuff in the back corner will be removed.
I am wondering if there are some simple things that I could do that could make an improvement to the sound.
I have read about the following things
1. Putting a carpet between speakers and listening position. Don't want to carpet the whole floor due to dust issues.
2. Getting heavier drapes.
3. Installing corner bass traps: can do this to only two of four bottom corners as the other corners are occupied.
4. putting tapestries on walls.
5. absorbers and reflectors on walls.
However, I do not want to convert my living room into a studio, as aesthetics are also an issue. So which of these would have the most impact? Are there any other simple things I could add, like specific kinds of furniture that help with the acoustics?
As you may have noticed, I am not savvy with audiophile lingo, but I hope I conveyed my issue clearly.
