High current audiophile amps - Recommendations.
Absolutely disagree.
My best ever upgrade was replacing a 120w Sherwood amp with a 50w Cyrus.
I had no idea how rough the Sherwood sounded until I plugged in my Cyrus. Even the audition in the shop had not given me any real idea of just how much improvement I was buying.
Absolutely.
Apart from protecting themselves from the people who might plug their domestic speakers into some kilowatt-output PA system, ending their lives in one short pop, I'm convinced that speaker manufacturers just use these numbers as some sort of decoration on the box! Meaningless.
If you still think you need Big Watts to drive those speakers, talk to the tube-amp guys ... some of them are getting wattage only in single figures out their amps!
Hi Sir, I have already concluded this argument the way you proposed.
Refer
http://www.hifivision.com/what-shou...ophile-amps-recommendations-4.html#post274474
http://www.hifivision.com/what-shou...ophile-amps-recommendations-5.html#post274674
I think this thread need to be closed as it is irrelevent now. I will add these links to the first post though.
These are called PreAmp Jumpers, i bought one from Audioquest cables (refer their website, accessories section) and it is worth buying a good one rather than using the lengthy RCA cables to avoid clutter. Regards.
These should be great. How much did they cost?
You can make one using 2 pairs of high quality RCA connectors and 1 meter High Quality Speaker Cables ..(Extra Unused Cables:D) Make it Twisted Pair using four cables of 15cm cm Each for each Interconnect, Solder It to the RCA Connectors and Try it and compare With the Jumpers, if you feel your cables are good go with it or else Jumpers;),
While twisted pair is as good as coaxial for a single independent cable, when you place several different cables near to each other twisted pair can't keep noise away as good as coaxial does. Back-side of an audio device invariably has several cables placed closely, so I won't recommend anything but coaxial. Some high cost cables have twisted pair inside a thick walled (0.5cm) tube. While that keeps noise away, it leads to a bit more capacitance, which is bad for any cable.
Some say that changing the Factory fitted Jumpers with high quality cable Jumpers Really improves the Audio quality..I have never tried it myself..may be I will try one day:rolleyes:
Don't bother. People who say that aren't used to before-after comparisons :-).
