HiVi Swan M20 speakers
PradyumnaNaik
Pune
Does anybody have prior experience with the Swans M20 speaker set or any Swans for that matter? Are these available anywhere in Pune?
Pradyumna
Thanks,
I wanted to audition them before placing the order. Do you have any prior experience using these or any other model from the brand?
Pradyumna
Dear Pradyumna,
All the Swan (HiVi) speakers comes with HiFiNage's Gratification Assurance.
@Abhi: This probably is the millionth time we are requesting this, can you ot least once visit major cities with a demo unit and let forum members have good listen and form some impression about them.
It'll definitely help people make an informed decision.
Just my 2 paisa.
Just my 2 paisa.
Dear ruenigma,
We have already offered HiFiNage's Gratification Assurance. :)
I recently bought Swan M20 2.1 from HifiNage, I would say that they are no doubt a good set of 2.1 but lacks powerful bass given the fact that the sub is not that powerful and is not meant to handle low freqs. you can always have a look at the specs. It gives a very pleasurable listen experience as far as music is concerned with a decent Bass. If you are in pune you can come over if you want to audition them.
yes.All the Swan (HiVi) speakers comes with HiFiNage's Gratification Assurance.
Hi pankaj, thanks for the offer. Where in pune? Can you share your contact details in Pm? I may drop in with my small speakers and we can do some A/B. What say?
Dear Pankaj,
I'm glad that you liked the speakers, For music usage: Swan D1080-IV is an amazing set of speaker and it can give old audio engine A5 a run for their money. You need to listen to it to believe it. Not sure about the new A5+. The sub-woofer of Swan M20W is a sealed enclosure sub and it won't give you voluminous low frequency output but it will give you tight bass.
The main problem is we are selling swan speakers and about 1-2% people have reviewed them so far. We think that people should review them so it will be beneficial for the other people to make the right decision. On the internet, reviews are the only sole factor in buying anything especially speakers but then also we have provided HiFiNage's Gratification Assurance so that customer should be confident enough when buying a particular speaker.
Dear Pankaj,
Hey can you compare those swans with Bose Companion 5
