Home Theatre Set up
Ramesh RN
Have booked Klipsch 5.1 (RP 280F) speakers and need suggestions on acoustics to be done to the room size 15 X 28 with a budget of 1 to 1.5 lakhs. Room will be used as multi purpose hall with some sports equipment. Please suggest
Ramesh
You have good budget , you can contact any HT dealer in bangalore and check for acoustics treatment in your room. That will simplify the job...
Here are some dealers
DNI Home theater
Tasmai autmation
you can google and find more...
DNI Home theater
Tasmai autmation
Not these two... I checked with others and they are expensive
