How Bass Travels?
Love4sound
Chennai
To Fm’s who have HT in flats.
I have booked a flat in 1st floor and would like to know if bass flows more to below or top floor? Bottom floor is stilt for car parking so not going to get any complaints. What has been your experience? Who complains more? Bottom or top floor neighbor? I have enough time and can modify to top floor if I want to.
Good thinking
You can not enjoy music or anything much else if you have neighbours irritated with you.
In addition to the answers to your question above do consider asking neighbours (once they move in) about this.
Even your question (from above) “would you know if bass flows more to below or top floor? “ would be an icebreaker 😊
Bass is totally directionless as @arj has mentioned. Human ears are not very sensitive to bass. We are most sensitive to frequencies between 2000–5000HZ, which are high frequencies. Bass sounds are low frequency sounds that are close to the resonant frequencies of the chest cavity. Humans do not actually hear bass, but feel it. Your body translates the vibrations into resonance in your body. This can cause your whole body to seem to vibrate.
Bass also has higher energy. It continuously pressurizes and depressrizes your room in all directions. They can actually make the walls move and that's how person on the other room will get the sensation. When it comes to the floor and ceiling, both will receive the same amount of enery. It totally depends on the thickness of the ceiling and the floor (which in a typical flat will be the same). Now to complicate things futher, your room has a resonant frequency somewhere in the bass frequency. So how much bass gets transfered to the flat above and below will depend on the dimensions of your room and the thickness of the ceiling and floor. I think the only solution is to put low frequency absorbers on the ceiling and on the floor (but I have no idea about where to get them and the cost).
Suggestions for house-warming gift to your upper floor neighbour (take your pick):
- Soundproof carpet
- Noise-cancelling headphones
- Meditation course 😀
But seriously I doubt there’s much that you could do to contain the bass. When the guy one floor below my adjacent flat, which doesn’t share a single wall directly with mine plays loud sound at home parties, I can feel the thump. Bass travels. The sensible thing to do would be to get cleaner bass (so it’s deep rumble instead of boom which is more irritating), play music/movies at reasonable volume at earthly hours, and make friends with the neighbours (they’d still complain, but to you and not the police) 😁
In practice I have observed that the bass vibrations below are SUBSTANTIALLY more than at the floor above.
This contradicts simple theory,. but it has been my observation. (YMMV :) )
The ceiling often has a False ceiling that probably reduces direct excitation of the slab above ...
I have a friend who lived in Paris for a while and he got constant complaints from the neighbour below regarding bass.
He installed thick rubber slabs on the entire floor below the carpet ... It did help but did not eliminate the Bass transmission.
The only way to eliminate sound transmission to a great extent, is to build a "Room-Within-A--Room"... Needs Great attention to detail in supporting the inside room....
This sounds logical. The subwoofer is always placed on the floor. A substantial part of the vibration (especially the down firing ones) will be passed to the floor as the subwoofer is mechanically coupled to the floor
If you don’t use something like svs sound isolation stuff, bottom floor which is coupled directly to the subwoofer get more bass. This is because the subwoofer vibrates and inturn it vibrates the floor to certain extend. If the concrete is thick, the bass doesn’t travel much to the floor below.
I am also actively researching this issue and thinking of using recycled rubber gym tiles below the flooring tile (actually below the sand lining under the flooring tiles, loosley coupled to the slab below)) within the listening area. (Floor slab-rubber tile-sand/filler-mortar-tile) - will this work?
Floor undelrlayment
One more option - green glue
Floor undelrlayment
You will have an iso acoustic floor?
Bass doesn't travel up or down, it travels everywhere.
Bass below 150Hz is not directional so all your neighbours will have the pleasure depending on the amount of concrete separating them....
Yes I am aware and would like to hear from others on their experience and want to know how they are dealing with this problem.
- Soundproof carpet
Haha sure. Have to pamper the neighbors for sure.
This is my assumption as well but opposite experience in my current scenario. I live in the top floor and my neighbor below doesn’t complain and I myself went down and checked. No disturbances due to bass from my room. But I will be always complaining to the below neighbors and he only has a 20k Sony system with passive subwoofer. My entire house will be shaking.
sure will keep it an option
Floor undelrlayment
Thanks for this suggestion. I’ll do some research on this.
Any update on this? the walls in my new apt are nearly done, need to decide on the bass isolation options pretty soon.
Hahah lot of unexpected things happened. The guy who I sold my apartment is a builder. He paid half cash and absconded due to some case against him. Now I need to start all over again 😁
This has been my experience too :)
My lower floor neighbor came knocking on the door many years back, complaining that his entire false ceiling was vibrating with all the bass being pumped into the floor through my spiked speakers. So eventually I got ingenious, and ended up with a 2 tier system below the speakers which has reduced the bass transmission into the floor. So I think, adding some kind of isolation under the speakers and subs might be of benefit here.
Coming to bass transmission through the walls, I found it to be minimal at best with solid concrete walls. Probably brick walls might not have the same degree of bass retention. But this means with all the trapped bass energy booming around in the room, I was forced to add bass treatment.
So my 2 cents would be that if you have concrete walls, then concentrate on the floor. But if you have brick walls, then keep the volumes sensible.
My Ht is in Apartment only. Till now not faced any issue. What is your suggestion for floor sranders and sub.
I think there are several options but depends on the weight of the speaker and how much one wants to spend. Below are some options that are well reviewed and well regarded. I tried some SVS sound paths under my tiny sub a long time ago, and I think they did something similar, but not sure if they stopped bass from travelling through the floor. My sub is very small with only 8 inches driver, so I dont think it needed much help in that regard.
But the bass issue was with my main speakers in a separate room. These speakers are big and heavy, so when placed directly on the floor with the spikes, I think they were coupling with the floor owing to their weight, and making the entire floor vibrate when listening to deep bass at high volumes.
Isoacoustics Gaia
Townshend seismic podiums
Stack Aava isolators
Still points
Sound foundations cera base
Noob sound spring isolators
