How much Volume is accurate for stereo ?
Tanoj
Not sure if this is correct place to post this ....
whenever i play any any music a question spins in my mind ... is the volume which i have set is accurate/correct
so usually i go by catching an instrument / volcal sound and gradually increase the volume until i feel its at natural sounding level
The way a cartridge has tracking force value declared for a cartridge , i always wish there was a sound ref value provided on album itself
so is there a measure/reference etc to make sure volume is at right level
Tanoj
My comfort level is when two persons talk while they are within 5 feet distance, my music sound has to be at same level so that either of them could overtake whichever is near to ear. Also I hope no external sound is coming in the way. Which is never practically possible.
So applies to all sources.
Tanoj,
Volume or sound pressure level really depends on your gear as well.
Some speakers really start opening up after you turn up the volume.
Going by your visit to my place last time you prefer a relatively high SPL.
We might have been listening at well over 100dB that day.
My comfort level for daily listening is around 90-95 dB.
Get a dB level meter app on your phone or tablet and you should be able to set up an ideal listening level at your home.
For me, the normal listening level is an SPL of 90-95db. But for rock and metal genre, I love to listen at a higher volume level, may be around 100-105db, but only for a shorter time like one CD at a time :).
I think the volume level changes with genre.
-John.
hi,
Nikhil and John what is your frequency i.e. hours and times in a day and week, do you people listen to at 90-95 dB ?
hi,
For me 90-100db for Rock and Metal might be once a week for 2-3 hours. But one listening session at high volume is only for 45 minutes max.
I do listen to moderate volume around 75-80db for 1-2 hrs daily.
-John.
Interesting thread!
We have discussed what listening levels we normally listen to...but I was wondering something just a bit different.
What spl is your normal soft listening level?
What spl is your normal listening level?
What spl is your moderately loud listening level?
And last...what spl is your loud listening level?
and are these levels the sustained music readings or peak readings?
thanks!
hi,
I've been enjoying a good run of recent. Listen almost 3-4 hours a day.
Sound pressure level is usually about 85 - 90dB.
I might crank it up a little to get some more slam every now and then.
Thank you Nikhil for your suggestion ... will try that
Thank you OM sir and all my friends for your valuable inputs
Tanoj
Guys there have been quite a few recommendations above on what is the Safe / Recommended / Stereo Cable etc volume setting.
However, I would like to repost the original query:
so usually i go by catching an instrument / vocal sound and gradually increase the volume until i feel its at natural sounding level
Tanoj
IMO there is Only 1 'Correct" volume.... the Volume / Sound level created when the original instrument was played in the recording environment.
1 Tabla or 1 Violin should be played back at the Volume / sound level created by 1 Tabla or 1 Violin.
1 Violin should not sound like 10 Violins..... Nor should it sound like Half a Violin !
That to me is the 'CORRECT" level.
If the room, sound system, hearing etc do not permit this, you can listen at another Volume level, but it is not true to the original performance.
This was actually a discussion in The Absolute Sound (TAS) magazine, many many moons ago, and as you can imagine, it did attract a 'healthy' ventilation of opinions :cheers:
The correct volume level to match the actual level at recording may not sound good.
It will change with listeners ear sensitivity, prefrences . In any case changes would have been applied while recording ( equaliers,synthesisers - I dont know what else is done) and hence the stage levels can not be used as a calibration.
I liked the description given by our FM hydrovac. See below thread
http://www.hifivision.com/amplifier...ofer-if-amp-doesnt-have-sub-woofer-out-3.html
Finally for me listening at 100 -105 dB is unthinkable. 90 dB for a short duration. 65 -70 dB is more to my liking
Tanoj
The term "volume" or "loudness" is a problem because this belongs to psycho-acoustics and this subjective personal feeling is only difficult to "measure".
A person feels and judges sound events by exposure time, spectral composition, temporal structure, sound level, information content and subjective mental attitude.
It is difficult to measure the exact level of different instruments and musical genres. This is because the level depends on how loudly a single instrument is being played and the ensemble in which it is being played. The combination of instruments being plaid in conjunction with one another will affect the safe amount of time one can listen to any given instrument or group of instruments and as such no recommended safe listening times are given.
The levels listed below specify how loudly an individual instrument can be played keep in mind that they are not played at this level all the time, but the instruments played with them can also make them louder than the level listed here.
Sound Level (dBA) Example
129 Rock or Jazz Music
114 Flute
112 Amplified Guitar
111 Steel Drum
110 Orchestra or Symphony
108 Trumpet
105 Pop Music
104 Cello
100 Bass Drum
92 Classical Music
90 Piano
82 Single Clarinet
Sound level in dB is a physical quantity and may be measured objectively. Loudness is a perceived quantity and one can only obtain measurements of it by asking people questions about loudness or relative loudness. (Of course different people will give at least slightly different answers.) Relating the two is called psychophysics.
And what many of us don't realize until we hear it, is that clean undistorted loud sound often does not sound that "loud." The key here is that in most of our home listening, there are small amounts of distortion caused by a lack of dynamic headroom. It's the distortion that makes it sound "loud" in a domestic setting. We've become accustomed to accepting some distortion with our reproduced music, because all amplifier's distortion ratings gradually increase as they approach their output limits or slightly clip the audio signals. When that happens, we turn down the volume, because distortion starts to intrude on our listening pleasure, and it sounds "too loud."
even i follow the same... concentrate on any instrument and set the volume to its natural sounding level... atleast close to it
Fully agree on this. Last week, a few of we FMs got together for a DAC comparo. Since the AP DAC appeared to have louder output which could be clearly perceived, we have used a dB meter (Android app) foe level matching but clearly, though the meter was showing same dB levels, perceived loudness of AP and also of another DAC was higher.
