How to connect sub-woofer in 2-channel stereo Amp
soundseeker
Dhaka, Bangladesh
Was wondering whether it was possible to add a sub-woofer in my set up which is 95 % of time is used to listen music..
My amplifier is Marantz PM7200 can anyone suggest what type of SWs should I look for to attach to this and how do I do it???
I have attached this picture of the back panel so pls take a look and advise is there anyway to make it happen.
There must be preouts which can be connected to subw prein & that will do the Job.
Few SW come with spk level in & out,so you can connect spk out of amp to that of SW carefully.
Thanks , Spirovious.
But I am a bit confused
The amp does have a processor in and out is that what you meant for pre outs and ins ?? Can you suggest brands of that particular type of SWs???
Your Amp does not have Pre-out to connect to the Sub.
The other way is to connect your Amps Speaker OUT to the Sub's Speaker IN & then connect your speakers to the Subs Speaker OUT.
You can check out some of the Polk Audio's DSW series subwoofers.They have speaker level IN & OUTS.
