how to : MARANTZ 1504 bluetooth enable
ankurjbl
pune
1) What is a cheap way to bluetooth enable marantz 1504 ?
2) How connect marantz 1504 on wifi. it has rj45 lan input.
i dont think it will work with 1504. it does not have 3.5 mm input and usb for this thig is for power only.
My Yamaha rx v477 has a network connection on the back panel. I installed Yamaha app for Android and it finds the receiver. If i play any music file it plays through the Yamaha receiver. maybe you need the Marantz app to do so.
If you are unable to run a cat5/6 ethernet cable to your AVR for some reason, you could use a ethernet adapter like the ones below.
https://www.amazon.com/dp/B005N6XBDO/
https://www.amazon.com/IOGEAR-Universal-Ethernet-Adapter-GWU627/dp/B004UAKCS6
Keep in mind the performance of wireless adapters differs based on various factors in your setup so it is not an optimal alternative for a wired connection. If you do get one of these and use, please post your feedback that might help others who may look for a similar solution.
