How to Play 192khz 24bit files on Arcam rDac?
santosh4
Does anyone know the solution to play 24bit 192khz files on rdac? which connections I need to use for it? coaxia?optical or USB connected or USB wireless?
Please advice,
I have attached the foramts that supported on rdac but the arcam company responded my saying I cant play the 192 or rdac, so I am so confused, is arcam cheating us ? the manual says support of 192 over coaxial and the support team responds to my mail saying it will not support 192 at all by whatever means and asked me to upgrade myself to irdac :-(
what to trust??
I use Coaxial mode only, and its LPCM so the questions is why did the support guys from Arcam are telling me that it does not support and the manual says its supports? any thoughts?
Hi All,
I got reply from Arcam, it supports 192KHZ over the Coaxial and an apology mail. The issue is resolved :-)
