How to play BluRay rips on BD player?
girish_67
Chennai
Could someone pls help by telling me how to play BluRay rips downloaded from the net on my Panasoninc BD player. I transferred the 8GB file on my pen drive, but the BD player does not recognize the file.
player exact model pls.... in all probability its just the question of player not supporting the media file or codec ....
Its a Panasoninc BD-75...could this be due to the fact that the file is too heavy to be read from a pen drive...just guessing :)
Check the manual whether it can play NTFS files from USB..If it still cannot play then your need to mux the file with MKV merge 3.0.0..I believe your downloaded file is in MKV format..BD75 can play MKV files.
Page no 6 of your players user manual says, USB (MP3, MKV, JPEG), up to 2 TB, so that clears everything .....
Here the screen shot of the page itself, to make it easy for you ..
Please check the type of file you have (both audi and vedio codecs and container) and post that info hereso that we can help you. Use media info or similar software on your computer. Many MKV files don't play on the stand alone players because of audio incompatibility.
Sorry...been travelling, hence the delayed response.
I recopied the file on the pen drive & tried once again...this time it played..but no video/audio..can see the status on the screen...nothing else...pls help!!! Belo is the a/v codec of the file:
* * * MediaInfo Mac 0.7.36.0 file analysis report.
* * * MediaInfo Mac is 2010 by Diego Massanti - Media Inspector for Mac :: Multimedia file analyzer for the Macintosh
* * * MediaInfoLib by Jerome Martinez - MediaInfo
Created on: 22-Nov-11 12:22:19 PM GMT+05:30
Report for file: The Bourne Identity 2002 DTS BRRip.mkv
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................1
Total Subtitle Streams for this File..............5
Video Codecs Used.................................AVC
Audio Codecs Used.................................DTS
SubTitle Codecs Used..............................S_HDMV/PGS / S_HDMV/PGS / S_HDMV/PGS / S_HDMV/PGS / S_HDMV/PGS
Available Sutbitle Languages......................English / Spanish / French / Spanish / French
File Format.......................................Matroska
Play Time.........................................1h 58mn
Total File Size...................................7.96 GiB
Total Stream BitRate..............................9 633 Kbps
Encoded with......................................mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Encoding Library..................................libebml v1.0.0 + libmatroska v1.0.0
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................V_MPEG4/ISO/AVC
Codec [email protected]
Frame Width.......................................1 920 pixels
Frame Height......................................816 pixels
Frame Rate........................................23.976 fps
Total Frames......................................170168
Display Aspect Ratio..............................2.35:1
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 3 Ref Frames
QF (like Gordian Knot)............................0.216
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................3
Video Stream Length...............................1h 58mn 17s 431ms
Video Stream BitRate..............................8 109 Kbps
Video Stream BitRate Mode.........................VBR
Bit Depth.........................................8 bits
Video Stream Size.................................6.55 GiB (82%)
Video Encoder.....................................x264 - core 98 r1649 c54c47d
Video Encoder (Settings)..........................cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=0 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=8109 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Video Stream Language.............................English
Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer Characteristics..........................BT.709-5, BT.1361
Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
Codec.............................................DTS
Codec (FourCC)....................................A_DTS
Audio Stream Length...............................1h 58mn 17s 435ms
Audio Stream BitRate..............................1 510 Kbps
Audio Stream BitRate Mode.........................CBR
Number of Audio Channels..........................6
Audio Channel's Positions.........................Front: L C R, Side: L R, LFE
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................24 bits
Audio Stream Delay................................10ms
Audio Stream Size.................................1.25 GiB (16%)
Audio Stream Title................................3/2+1
Audio Stream Language.............................English
Subtitle Stream #1
Language..........................................English
Format............................................PGS
Codec ID..........................................S_HDMV/PGS
Codec Info........................................The same subtitle format used on BDs/HD-DVDs
Subtitle Stream #2
Language..........................................Spanish
Subtitle Stream #3
Language..........................................French
Subtitle Stream #4
Subtitle Stream #5
