ontherocks
Two two-way speakers are installed in the trunk lid of the car. Recently the whole trunk lid has started rattling/vibrating a lot when I crank up the volume. It rattles more when the lid is closed than when the lid is opened (at any angle). It appears more if looked/listened from the outside. I have tightened all screws/nut/bolts, the lid lock, nevertheless.
Will filling up the empty space inside the lid with something......say with something like scrap foam used in sofa sets.......reduce the rattling? I also have a lot of white 0.5mm foam sheets (the ones used to wrap appliances/TVs) lying around. Would they be useful?
