how to set speaker levels accurately on yamaha rxv 583?
Usually the auto setup feature (calibration) takes care of the same. Please refer to Owners manual for detailed steps...
If you feel after doing this the levels are a bit low, you can manually adjust the same ....refer owners manual for the steps....
Alternatively, if there is a challenge in output, suggest you post this query in the "Yamaha Owners Thread", you will get a quick response.
