How to use Marantz NA6005 for volumio?
Install volumio on your single board computer and connect it with either USB / coax or optical outputs from your SBC to your NA6005
NA6005 also has a dac
And 3 digital inputs
It's a network streamer cum dac but by using volumio you would take it's network streaming out of the picture which should be OK depending on what hardware you use to feed digital data to it externally
Dear Friends,
Pls help me, how to stream music from Volumio to Marantz NA6005
I don't think you can directly. It is not an endpoint. You need to add a device such as a Raspberry Pi with Volumio installed on it. Add a board which outputs digital signal like Optical or Coaxial. Feed that to your Marantz digital inputs if it has. If not, then you would need an external DAC which then needs to be connected to the Marantz.
MaSh
