hyundai i20 Megna 2012 Audio Suggestion
kapil.saini
Delhi
Hi Friends,
i ma using hyundai i20 Megna 2012, now music system not working (Company fitted) i want to change it with new. Please suggest me which one is best and perfect fitted for i20.
List out your requirements and try looking up at Amazon and flip kart. I guess today is last day of the sale.
Do mention your requirements and budget, which would help members provide focused suggestions.
MaSh
Please mention your budget.
Also, looking to change both front and rear or only front or rear ? There are plenty of configurations available based on the budget.
For best setup, do consider amplifier because amp is the key to get most from speakers. Amp may costs between 7k to max. Then damp the doors (at least front doors) to reduce the rattle/vibrations and allows speakers to function well.
Speakers, you shall decide based on your budget.
