IEM suggestion needed!
ckhurana
Ghaziabad
I have been using my trusty Tennmak Pro Dual Dynamic Driver IEMs since 7-8 years now. Other than going through a couple of MMCX cables, I had to change nothing.
Recently, the right side IEM has gone a bit low (a change of cable does not sort the issue), so I am on the lookout for a replacement.
Your suggestions are welcome as per my use case below -
Usage -
  1. With laptop via the standard 3.5mm jack
  2. Android usage on S20FE via the USB-C DAC (Abigail Pro).
  3. Should be resilient enough to handle long walks and active use.
Music genres -
  1. Standard Rock / Pop
  2. Trance / EDM
  3. Instrumental / Soundtracks (Hans Zimmer and so on...)
Sound stage -
  1. Neutral but bass friendly
  2. Accurate with natural lows and treble.
  3. Should be immersive enough / support a wide soundstage - especially for watching movies.
  4. I will be using custom EQ on PowerAmp so accurate response appreciated!
Design -
  1. Prefer replaceable cables (2 pin or MMCX version) with Mic/remote.
  2. Also shall use them with FiiO - BTR11 (so need a compatible short cable)
Cost - Preferably under INR 5-6K / USD 60.
Please suggest a suitable upgrade preferably available in India!
Thanks,
CK
Check out the Sennheiser IE200. Slightly above your budget but dynamic, balanced and musical, great value for money. Bought it a month back and thoroughly enjoying using it with the Shanling M1 Plus DAP. It scales up well with the source.
