In need for a new set up, Dali Zensor 7 just purcased
French
The netherlands
Hi there!
Im busy with setting up some new sound for my home theatre.
In first i bought 2 new Dali Zensor 7 towers. Hope to see them here in a couple of days.
I went to an audio store to listen to them and i was sold!
It took me a while till i finally bought them. Later i want to add the Zensor 1 as rear, and 1 vokal in the middle.
For now i am using an JVC RX-5052 receiver. Its an oldy and real no deal for these speakers.
So im in need for a new receiver as well.
In first my eye catched the Denon 1912. Why? the audio shop told me.
And i found out the quality of this brand.
Now there are new models like the 1513, 1713 and 2113.
I listen sometimes music... not real the pro for a choice, so it will be most of the time Movies the receiver will do.
Should i go for a Denon 1912 (2nd hand?) or the new 1713 for example.
Or some other brand.
my budget is more or less 300.
Thanks a lot,
Frans
Do you have Harman Kardon available in your area? If yes, try to get an audition of Harman Kardon. Those receivers offer a lot of current on the tap that is much needed to drive a floor stander.
Second best choice you already have. Get the Denon 1912 or the next higher model, whichever fits within your budget.
Allright, i will give a thought about those harman kardon(actually not my favorite, seems in the low segment they arnt that good)
I will compare the Onkyo TX NR 807, denon 1912, and i found out the Marantz rs5006 should do his tricks as well...
Damn hard choices allways:P
Thanks a lot
