iPad to RCA Cable
Nikhil
Moderator
Staff member
Hyderabad
I am looking to connect my iPad directly to my preamp. Using the headphone plug is really not very good.
Have read online that the way to go about this is to use the 30 pin out of the iPad which gives out much better line level audio signal.
Need help to locate a supplier for a suitable cable like the one(s) below:
I think you can try your luck in any of the car audio shops as I have seen similar kind of a cable for AV purpose to play video thru ipod/iphone to the receiver in the car. I hope they might be stocking the RCA only cable as well with the 30pin ipad/iphone cable.
