Jamo S406 @ 14k worth??
delhite2
is buying jamo s406 at 14k worth buying, they are JAMO, they are floor standers.
any opinions and reviews?
I heard these, and personally, I felt these were the weakest speakers by Jamo. Look for the S606 or S718's if your budget permits. Else look for some good bookshelves. Finally, your ears are the judge. If you find them good for your kind of stuff, go for it.
is buying jamo s406 at 14k worth buying, they are JAMO, they are floor standers. any opinions and reviews?
They are only 6 Ohms impedence, and it is a very old model if it feels ok go for it or else there are some good brands available for around 25k if you can expand your search.
Hope this helps
Sub
