jamo speaker placement
annapl
PUDUKKOTTAI
i have a jamo 626 fronts how to place it for accurate results it has a side firing woofer so should i place woofer facing towards the wall or facing inside?
You should try both placement options....minimum run it for a week and see which placement serves better performance.....ensure that you use or hear the same sources and content as reference to decide......wall facing would mean more bass ...this is tricky as you need to ensure ample distance...else you may face muddy bass
