Kaiboer k6 HDMI problem
kaushik
i am facing a problem
when i open kaiboer K6 file manager while the PJ model : AcerH5360
connected to the unit .
It tries to scan the USB disk and when i browse the file,
* the mediaplayer unit resets ,Kaiboer moves out to the home (from the directory tree)
* the HDMI connection goes off
* The Acer rescans the HDMI and comes back
Seriously i am not able to play any stuff from HDD to the projector .
But there is no such prob with USB pendrive !
This is when the media player is connected to projector, with TV it works like charm !
Anyone have any idea on this ? :mad:
Seems like a HDMI Handshake issue with PJ.
Try connecting any other input on PJ such as Composite. component.
If it works fine, then certainly the issue is with HDMI connection.
Switch off you HD Player & PJ
Remove all connections from PJ other than HDMI
Start you PJ first & let it boot to full brightness.
Turn on player and let PJ search the signal (If auto search is on)
It will try to locate first available signal that is now HDMI.
It should work now.
