Kdl-40ex700
designer
My regards to all the tech gurus!
I need your help and advice...
I am planning to buy a LED TV.
I was going through the models of Sony Bravia
KDL-40EX700 and
KDL-40EX600.
Motion flow of KDL-40EX700 is 120Hz...but
Motion flow of KDL-40EX600 is not mentioned. Does anyone know what it is?
What is your take on between these 2 models.
In grey market the cost is less by almost 20K.
Is it worth taking the risk?
Thank you.
KDL-40EX700 and
KDL-40EX600.
Thank you.
Motion flow feature is to show fast moving clips/action/movement smoothly adding extra frames.
EX600 is 60Hz means each frame is shown on TV in 1/60 second where 120 Hz found on EX700 shows each frame in 1/120 second so making picture quicker and better.
EX700 has more features than EX600.
I have not checked both tvs side by side so cant comment on the picture quality difference.
I did side by side comparison and found ex600 better even though I went to buy ex700. Tried comparing high action scenes and found no difference as I was also very particular on ex700 motion flow.
