Kenwood KT592S
jayants
Calcutta
Hello!
I am looking for some inputs here if possible.
I have a Yamaha Receiver which I hardly use as the only time I use is when I wish to listen to FM. It has taken a lot of space which I wish to shift it to my video setup room.And so I need to buy a dedicated Tuner.
Got information of a 2nd hand Tuner - Kenwood KT592S in good condition.Any suggestion whether its worth a buy?
You can do one thing- have a audition of the tuner. Check the tunning at different frequencies. Make sure the Stereo option is working well. Spend at least half an hour- if it is playing well, you can go for it. Moreover the amount you are paying is justifying its worth.
Thanks. Will check things.
